Discussion topic: Box still initialising - none of the trouble shooting seems to work
Message posted on 17 Jun 2024 12:48 PM
Box still initialising - none of the trouble shooting guidance seems to work
Message posted on 17 Jun 2024 01:12 PM
Re: Box still initialising - none of the trouble shooting seems to work
Has your Sky box been worked ok up to now? What troubleshooting have you tried?
Message posted on 17 Jun 2024 01:46 PM
Yes it had been working without any problems before
Message posted on 17 Jun 2024 01:51 PM
You still haven't told us what troubleshooting you've tried. First switch your box off at the plug for 5 minutes and then check whether or not it moves on from initialising after several minutes when you turn it back on.
Check the dish connections at the back of the box while it's turned off. Make sure they're securely fitted.
If that doesn't resolve it, there's either a fault with your Sky box, or more likely with your dish/cabling Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you would need to engage a local satellite installer to investigate.
Message posted on 17 Jun 2024 02:20 PM
No satellite signal need a specialist engineer
Message posted on 17 Jun 2024 02:39 PM - last edited: 17 Jun 2024 02:42 PM
You may need an engineer but not a specialist engineer. Your duplicate post has been removed.,
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
Message posted on 17 Jun 2024 02:40 PM
Do you have Sky+ or Sky Q? Tell us more about the problem you're having.
Message posted on 17 Jun 2024 02:45 PM
A normal sky box (no sky Q) , it keeps showing the same error saying the Sky box is still initialising, no matter any trouble shooting we do
Message posted on 17 Jun 2024 02:46 PM
@Stephenosunsami You've posted on a thread within the Sky+ forum, Sky + is no longer supported.
Do you actually have Sky Q?
Message posted on 17 Jun 2024 02:47 PM
The last two posts are directed at @Stephenosunsami who has confusingly posted on two different boards.
Message posted on 17 Jun 2024 02:53 PM
@ViviUL wrote:A normal sky box (no sky Q) , it keeps showing the same error saying the Sky box is still initialising, no matter any trouble shooting we do
@ViviUL What are the signal strengths and qualities in Services > Settings > Signal. All four white bars should be at least half way across. A Sky+HD box won't initialize without a satellite signal.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 17 Jun 2024 04:27 PM
I am unable to check settings, new message no satellite signal. I followed the guidance and restarted it couple of times waiting for 15 mins but the issue remains
Message posted on 17 Jun 2024 04:34 PM
"No satellite Signal" should not stop access to the settings menus
Message posted on 19 Jun 2024 08:49 AM
I have just been able to check the settings and no signal at all the boxes are empty, lock indicators 1 and 2 "not locked" , network ID /transport stream "null". What does this mean ?
Message posted on 19 Jun 2024 09:10 AM
@Mark39 wrote:You still haven't told us what troubleshooting you've tried. First switch your box off at the plug for 5 minutes and then check whether or not it moves on from initialising after several minutes when you turn it back on.
@ViviUL As per @Mark39 's response above.
