Discussion topic: Blurred picture and sound
This message was authored by: Albert1
Message posted on 18 Sep 2023 12:08 PM
Hi did as suggested when into settings some channels has no signal strength or quality in input 1 and some in input 2. How do I correct this. Thanks
Find out more
Message posted on 18 Sep 2023 12:12 PM
Re: Blurred picture and sound
"No Satellite Signal" usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out sky or a 3rd party satellite/aerial company
Note: If you have a communal dish then this is maintained by your landlord/building management and NOT sky
