This discussion topic is read only Discussion topic: Audio description
This message was authored by: Jennifer+murrihy
Audio description
How do I turn off audio description on a recording
Locked
Re: Audio description
@Jennifer+murrihy
Press help on your Sky+ remote (located to the right of the back up button, which is directly below the down arrow) and press the left or right arrow to toggle audio description On or Off, then press select to save the setting
@Jennifer+murrihy If you have recorded something with Audio Description turned on, then I don't think you can remove it. But follow @TimmyBGood instructions for turning it off going forward
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Locked
