4
This discussion topic has been answered Discussion topic: Adding channels to favourites on Sky+ box
This message was authored by: Chuddy
I have a Bang & Olusen TV with with amongst others a Sky + box and have since the oputset used  the B&O hand set to control all aspects of the TV, Sky etc. With the latest BBC 1 channel number change announced by Sky I need to update and add the new channel number to my 'favourites'. The Sky home page has changed and there seems to be no option for this that I could find. Has anybody exerienced this and has managed to update theirs please?
Re: Adding channels to favourites on Sky+ box
Press the services button on the remote and go to Options > Favourites then you can make any changes you want by pressing the yellow button to add or remove a channel then green to save the changes when you are finished.
Avatar for Chuddy
Unfortuantly this will not work in this instance as I am using the TV's own handset and not the Sky one fopr all control, navigation etc so I can't acess the serice button you refer to . But anywaay thank you for your very prompt reply.
If your remote has an Info button, this can sometimes be used to go to the services menu
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for Chuddy
Thank you Annie, after a lot of fiddeling have got it and am now a happy bunny😀
