Discussion topic: Accessing Catch Up TV on SKY+HD
This message was authored by: Martyn661
Catch Up TV says that I can't access it because my Sky HD+HD box isn't connected to broadband but I believe that it is.
Re: Accessing Catch Up TV on SKY+HD
What does the Network tab in the settings say?
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
Avatar for Martyn661
Hi
I just went in to Network and clicked on my internet settings and it now works thanks. I also turned the box and router off for a while before switching back in so I guess it could be that that solved it - more likely the former though.
Thanks for pointing me in the right direction.
Martyn
