- Mark as Read
- Report comment
Kei+M
If you are an early riser or a night owl you may have noticed your main Sky Q box takes a while to turn on whilst your Sky Q Mini or Sky Go does not work at all.
Lizalexa asks:- I have just got Sky Q but if I try to switch it on in the early morning it says its not connected but by 6am its back on. Any ideas?
By default your Sky Q boxes use an Eco standby mode which means that the boxes enter a low power mode between 2:30am and 5:50am. This means that between these hours you may notice it takes a few minutes to turn your main Sky Q box on and that you cannot use your Sky Q Mini or Sky Go.
If you use Sky Q between these hours we recommend choosing another standby setting. To change your settings:-
- Press Home on your Sky Q remote, and select Settings , then select Setup.
- Select Preferences then Standby mode, and select your preferred setting.
Please note: All boxes should be on the same energy saving settings.
To find out more about the different standby settings visit our page here.
Leave a comment
Comments have been disabled
Comments (0)
