Discussion topic: sky stream & a Dell monitorave chec with sound.
This message was authored by: Jon19591
I have done all the trouble shootining steps on steam, now this used to work no problems but the Puck was off for a few months.
1. reset the puck and paired the reamote.
2. checked the firmware on the monitor all upto date
3. still no sound?
I do this thats this has to be a puck issue, however when I tried this on a LG tv the sound came thought without a problem.
the odd thing about this is when i set this up it worked on the monitor but now dose not wan to work at all.
andyone got any ideads
This message was authored by: Jon34
Re: sky stream & a Dell monitorave chec with sound.
Check the audio output format in the puck
A monitor is less likely to support DD etc - set to pcm
Otherwise reset the audio settings on the monitor and check the volume
