Discussion topic: how do i connect sky stream to sky soundbox.
This message was authored by: SnoooTwo
(On the Sky Q you could cable direct from Qbox to Sound
Re: how do i connect sky stream to sky soundbox.
@SnoooTwo
Should be the same setup but with the Steam puck in the place of the Q box.
@SnoooTwo
Note that Stream doesn't have the Soundbox modes or any of the other interaction it did with Q.
This message was authored by: Mister_Dalek
All info is here:
https://www.sky.com/help/articles/setting-up-sky-soundbox-sky-stream-puck
