Discussion topic: Will sky stream work through a Denon AVR 2400h into an old Pioneer screen
Message posted on 24 Jun 2024 05:41 PM
We currently have Sky Q box into a Denon AVR 2400H into an old Pioneer screen. We have loads of trees in our garden, so in summer, when thhe leaves are out, we quite often have no satellite signal. Can I replace Sky Q with Sky Stream to solve the problem? We have a fast internet connection.
Message posted on 24 Jun 2024 05:51 PM
Re: Will sky stream work through a Denon AVR 2400h into an old Pioneer screen
@TheLoneGenius wrote:We currently have Sky Q box into a Denon AVR 2400H into an old Pioneer screen. We have loads of trees in our garden, so in summer, when thhe leaves are out, we quite often have no satellite signal. Can I replace Sky Q with Sky Stream to solve the problem? We have a fast internet connection.
How fast is your internet connection?
Sky Stream needs a stable connection with a minimum speed of around 30Mbps to function with any reliability.
Be aware that it is very different to Sky Q. You don't record in the same way as you do on Q. You can add programmes to a playlist to stream at a later date, but it's down to broadcasters to make these streams available.
Message posted on 24 Jun 2024 06:36 PM
Thanks. We get 100+ mbps so that's OK and we don't record much so again no problem. I'm just worried whether it will actually work.
Message posted on 03 Jul 2024 07:44 PM
I have Sky Stream going through my AVR X4300H without any issues, I know it's a different model to yours, but I would expect the same results.
Message posted on 03 Jul 2024 08:18 PM
Using Stream with a Denon X3500H and a Sony 55" XF9500 TV, both 2019 vintage. All work flawlessly together.
Your 2400H is a 2018 model should be fine. Not sure on the TV side without a model number.
