3
This discussion topic has been answered Discussion topic: Will live sky sports on stream play from start half way through?
This message was authored by: Myloceratops
What the title says, essentially I am looking to get a sky sports package.
Either the rolling standard (£30 a month) or the F1 package (£20 a month) for a short while.
However, I know I won't be able to watch live on some of the F1 races.
so I would like to start them from the beginning when part way through.
only issue is that I don't know if on either package using sky stream if that will allow me to do that?
This message was authored by: HavencroftKev Answer
Re: Will live sky sports on stream play from start half way through?
@Myloceratops I believe that when you turn the Sky Sports F1 channel on mid race it gives you the option to watch from start.
I have put F1 in my playlist and have been able to watch practice sessions from the beginning after they've started from there.
Hope this helps.
Hope this helps.
Avatar for Myloceratops
Ah amazing, I presume getting the F1 package will still allow me to do this!
Yes I'm pretty sure that will be the case.
