28 May 2023 04:12 PM
So other than the activation cost of 39.95 per puk how much per month will it cost extra if I got another 5 units is it just the 12 whole home sub or is that per puk ?
28 May 2023 04:13 PM - last edited: 28 May 2023 04:14 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Dowhat
It's just £12 per month so that covers all if you got 5 for example - it's not per device.
Thanks,
Tim
Thanks,
Tim
Posted by a Superuser, not a Sky employee. Find out moreIt's one 12.99 whole home per household
28 May 2023 06:03 PM - last edited: 28 May 2023 06:07 PM
Posted by a Superuser, not a Sky employee. Find out moreUsing six pucks, even for HD, would require more bandwidth than the best FTTC can deliver.
Note that pucks cannot be split between households: Sky has mechanisms to detect and either block or charge for such use.
28 May 2023 06:24 PM
Thanks I have Virgin 1gb and a wired Ethernet cable to each room so base on you answer should be ok
28 May 2023 07:20 PM
@Jporch316 £12.99 a month? Are you sure
28 May 2023 07:26 PM
Posted by a Superuser, not a Sky employee. Find out more£12
plus 99p tip ......
@Jason+Golding wrote:@Jporch316 £12.99 a month? Are you sure
@Jason+Golding It's definitely pm but it's £12 not £12.99
cc @Jporch316
30 May 2023 08:35 PM
Hi do you know if I sub to the whole home if it allows you to use sky go on an Xbox x or us it just a sky q / sky q tv subscriptions
thanks
30 May 2023 08:36 PM
Yes the wholehome subscription allows games consoles.
Thanks,
Tim
30 May 2023 08:37 PM
Thank you for such a quite response
30 May 2023 08:38 PM
Posted by a Superuser, not a Sky employee. Find out moreNo problem @Dowhat
Have a good evening 🙂
Thanks,
Tim
30 May 2023 08:40 PM
Posted by a Superuser, not a Sky employee. Find out moreThe Xbox sky go app has just been updated as well - it's pretty cool 👌
11 Jun 2023 12:42 AM
Hi sorry not sure if I'm posting correctly
but could you advise
i have newly ordered and subscribed'whole home' for streaming with ultra fast plus broadband etc
but I have only been sent 2 boxes am I being thick but they don't cover all by bedrooms I would need to more should they have sent them or would I have to pay for them ,
thanks in advance of any advice
11 Jun 2023 02:33 AM
Hi you will have to pay 39.95 each for two more so 80 pounds
