Discussion topic: Weak or no signal
This message was authored by: Vinzoe
Message posted on 16 Feb 2024 07:12 PM
Weak or no signal
Signal lost
Weak or no signal
Check your connections
This message was authored by: Nigelb1972
Message posted on 16 Feb 2024 07:17 PM
Re: Weak or no signal
Can we have some context to this? If you have a weak signal, this can only be weak WiFi as there is no other signal
Find out more
Message posted on 16 Feb 2024 07:21 PM
This sounds like a message a TV outputs if the device isn't connected rather than a Puck message.
@Vinzoe check the connection of the HDMI cable between your Puck and TV if all secure try a power cycle of your Puck.
MikeAlanR
