Discussion topic: Wall mounted TV to Sky stream box
Message posted on 26 Sep 2024 04:27 PM
I have just got Sky stream and have a wall mounted JVC TV.
My problem is when I plug the cable into the HDMI port , because of its length I can't then hook the TV back onto it's brackets because it's too long.
There's a USB port on the side (photo below) which I thought would solve the problem so I bought an adaptor cable but it doesn't fit the USB port as it's a different shape
The small writing on the TV next to the USB female port reads
USB
5 vdc
max 600 ma
It's shorter and deeper than a standard USB port
Any ideas much appreciated
Steve
Message posted on 26 Sep 2024 04:28 PM
Re: Wall mounted TV to Sky stream box
Message posted on 26 Sep 2024 04:35 PM - last edited: 26 Sep 2024 04:39 PM
@Gogetemfloyd Best to get a HDMI cable that has a right angle 90 degree connection similar to this one from the well known online retailer (click on the 90o option).
Message posted on 26 Sep 2024 05:13 PM - last edited: 26 Sep 2024 06:22 PM
Unclear what you were hoping to do with that adapter, but a USB port on a television set cannot either power a Stream puck or accept video input from one.
Message posted on 26 Sep 2024 05:30 PM
Thanks GD1
That looks just the job. Didn't even consider a right angle fitting.
I'll order it now..
Cheers
Steve
