Discussion topic: Technical fault with channel please wait for programme to load
This message was authored by: P11RAR
Re: Technical fault with channel please wait for programme to load
I'd thought we had tried that honestly. So when the message appears or the live tv stream fails to load, press the home button?
This message was authored by: Daveyboy2503
Oh yes I'm getting the same there seems to be issues daily .ring sky turn it on and off brilliant!!! I'm so regretting getting this I would advise people to stay clear
This message was authored by: SteveP9
I also have the same problem. Sky said to factory reset which I did. It worked for 10 minutes then froze again. "technical probelm" etc
No issues with Netflix or any other platforms.
Believe it was mis sold to me and I am pushing to cancel
This message was authored by: Jedster2000
Same here.  All other streaming services work fine - just not the Sky ones.  Embarrasing.
I have now cancelled. As it is a streaming service which cannot be provided, they will accept the cancellation with immediate effect.
now changed to Amazon Firestick. No issues at all.
Steve
This message was authored by: Crabit
Yep,same problem with me, resetting the puck either off/on from the remote  or powering down then on again didn't work, however, resetting from the 'Settings ' menu did work  + refreshing apps'  this is my second puck, which worked fine for approx' 2 months  !and seems to be working fine again,  quite frustrating, but good luck with getting it sorted.
Graham.alexander
This message was authored by: Laz5
I'm having the same issue. I have had the sky puck for a year. No issues until I moved house. Now I just can't seem to make it work. I do think it's a weak product. Sky rakes in a lot of money and can't make this thing work. Really frustrating that I pay £109 for a service that doesn't even work! Ridiculous!
This message was authored by: Hunter2660
Moving house would seem to be the issue. Have you checked your broadband speed via the Netflix app on the puck? Is the puck connected by ethernet or wi-fi? If wi-fi where is the router now situated? Has the puck a good line of sight to the router (not behind the TV etc.). Unfortunately there are so many variables it could be hard to track down.
Completely agree. What a lot of people don't realise is that there are numerous local factors for a property which will affect a Wifi network.
This message was authored by: AngSimms
Did you ever get this issue resolved? I've got 300mb download Ethernet connected, wifi turned off on my Stream, another Stream connected by WiFi only, all standby options etc turned off..... I didn't set up the Streams until after the 14 day cooling off period. I'm pulling my hair out.
Did you manage to cancel?
This message was authored by: Robster1978
I've had this problem relentlessly - Sky don't care and usually just tell you to reset it and turn it off and on then pretend it's not a common error despite forums like this where lots have the same issues. I have to watch TV via the actual TV apps
as Sky is such a nightmare - I don't know why I'm paying them anymore
