Discussion topic: Technical Fault on top of TV for past week
Message posted on 15 Sep 2025 08:18 PM
I keep getting the error message "There is a technical fault. Please try again later" for the last week. Resetting the puck or switching the system off hasnt worked
excellent wifi, connection etc, gone through all fault finding steps.
this is the 3rd puck due to "issues"
anyone have a resolution ? Im not receiving what im paying for so next step is a complaint
Message posted on 15 Sep 2025 09:00 PM
Re: Technical Fault on top of TV for past week
Hi @Jodie1306
If your in puck number 3 it's likely to be something local to you causing issues. I have 2 Glass units and 4 pucks and their fairly solid. For the community to assist you will need to provide some more information. Remember we are fellow customers not sky and know nothing about your set up unless you tell us.
Who is your ISP? What speed are you getting (broadband and puck?), have you run a test in netflix etc. what steps exactly have you tried?
If you do want to make a complaint see: https://www.sky.com/help/articles/how-to-make-a-complaint
MikeAlanR
