Discussion topic: Streaming puck drops sound then picture freeze
Message posted on 26 Jan 2025 06:19 PM
Message posted on 26 Jan 2025 08:43 PM - last edited: 26 Jan 2025 08:43 PM
Re: Streaming puck drops sound then picture freeze
Hi @Chippyjack
That will be th issue. Sky recommends 25Mbps for HD and 30Mbps for UHD. You have very little headroom for other things using your network.
What speed should your broadband be? Is Sky your ISP? You may get more stability using ethernet and turning off WiFi in the settings on the puck.
MikeAlanR
Message posted on 27 Jan 2025 07:22 AM
Thanks for your response
I have sky full fibre 500 and also a mesh setup to send the wifi around to full house, sky test says everything working well with a guaranteed minimum 400mbs, I think it's a bandwidth problem that only seems to be a problem at busy times of day when most other people are using Internet. I hope this streaming tv thing isn't going to be regrettable
Message posted on 27 Jan 2025 07:48 AM
@Chippyjack wrote:Thanks for your response
You need to check the speed actually being received by the puck. To do this, open the Netflix app, navigate to the get help menu and run a network check. Run it a few times and see if the speed is changing a lot.
