Discussion topic: Streaming Netflix picture quality heavy shadowing on faces
Message posted on 04 Feb 2025 12:53 AM
Why do actors faces appear bruised in shadow areas
Message posted on 04 Feb 2025 08:21 AM
Re: Streaming Netflix picture quality heavy shadowing on faces
@2Bob55 they shouldn't but it sounds like the picture settings on your TV need adjusting especially if you are watching UHD.
Message posted on 04 Feb 2025 08:59 AM
@2Bob55 wrote:Why do actors faces appear bruised in shadow areas
Netflix is known to use quite heavy compression on much of its content, especially if you're on one of the standard HD subscription tiers. This can cause some posterisation-type effects, particularly on dark shadowy areas of the picture where there isn't much detail.
The Premium subscription tier is better as it offers higher 4K resolution and less compression, as well as HDR on some content.
Your TV's picture settings can also affect image quality, especially if you have a lot of processing options turned on.
