9
Discussion topic: Sly puck Dolby Atmos issue
This message was authored by djk4yah This message was authored by: djk4yah
Hi Guys, I keep having to switch off and on Dolby Atmos on my Samsung S95B TV for my Sky puck to stream Dolby Atmos content through my Samsung hw-q990b .
 Dolby Atmos works fine with other devices,  like my Amazon firestick.
So I've isolated the issue, so I know the problem is with the sky puck.
I've tried numerous workarounds and much troubleshooting with no joy.
Any help to resolve this would be much appreciated.
This message was authored by Chrisee This message was authored by: Chrisee Answer
Re: Sly puck Dolby Atmos issue
@djk4yah check that the Samsung TV HDMI digital audio output format is set correctly IIRC it should be set to pass through check p220 of the E-manual
This message was authored by SlenderRobert This message was authored by: SlenderRobert
Can someone move this to the Glass/Stream forum please?
djk4yah
Ooops sorry my bad.
Can i delete on here? then i can repost in the correct category
This message was authored by Chodley This message was authored by: Chodley
@djk4yah wrote:
Ooops sorry my bad.
Don't worry - someone will move it.
This message was authored by Daniel0210 This message was authored by: Daniel0210
@djk4yah
Moved.
▪️ I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
djk4yah
Yeah I did that, I've followed all  the recommended settings but I still have to switch atmos off and on every time i start the tv for it to work.
djk4yah
So just to clarify, I've got my sky puck's sound setting - Digital audio output HDMI set to Auto.
My Samsung S95B TV sound settings as - Digital Output Audio set to Pass-Through.
So everything works fine with Dolby Atmos showing up on the soundbar and on the TV's info, but when I turn the tv on the next day I have to manually go into the sound settings on the tv and switch Dolby Atmos off and back on again for everything to function as normal.
Any suggestions please so I don’t have to do this every time I switch the tv on?
I have tried changing hdmi cables and  unplugging everything and  resetting everything but it's still the same.
This message was authored by Dolby+Dan This message was authored by: Dolby+Dan
I'm having the same issue with my Sony Bravia and Sony soundbar. My Sky Stream refuses to play Dolby Atmos without audio dropouts. No other streaming device (Fire Stick 4K/Apple TV 4K & TV) has this issue when streaming via the eArc port. Sky will acknowledge issues and promise that an update will fix things and it hasn't. I've only been a costumer for 6 weeks and so far I'm not very impressed with the device.
djk4yah
Problem Solved!
I tried switching the sky puck on first and then the tv. Well it's working fine without me having to go into the tv's sound settings and switch Dolby Atmos off and on for it to work.
I don't have to do that with my Amazon firestick.
Usually I switch on the tv then the device I want to watch.
Anyway I can live with that.
Has anyone else been through the same thing?
