This discussion topic has been answered Discussion topic: Sky streaming puck won't stay in Dolby Digital
Message posted on 02 Dec 2024 07:13 PM
Message posted on 03 Dec 2024 10:48 AM
Chances are the devices (soundbar/AVR & puck) are negotiating what sound formats are mutually supported during a periodic handshake and incorrectly concluding that that only PCM stereo is mutually supported.
When setting the puck's sound format/output to Passthrough, it should stay as passthrough, outputting the Dolby Digital Plus as a raw bitstream for external devices to decode without going through handshaking.
Check that your soundbar/AVR is right up to date with the latest firmware - firmware update often include fixes to bugs/incompatiobilites when using HDMI connected video and sound sources. Then set the sound output format to Passthrough to send the sound data out to your soundbar/AVR without any internal decoding going on.
Message posted on 02 Dec 2024 08:01 PM
Re: Sky streaming puck won't stay in Dolby Digital
I have noticed that the sound setting indication reverts to pcm, however dolby digital is still active. I use passthrough and get the same indication. My puck is connected to an avr and is definately getting dd while sound setting shows pcm.
Whi
Message posted on 03 Dec 2024 10:56 AM
As stated in my reply, though the setting shows PCM stereo Dolby Digital is being passed through.. It appears to be an indication bug in the setting.
If I select passthrough and then back to PCM then I get PCMstereo. Selecting Passthrough returns DD output but the indication reverts to PCM on exiting the setting.
Message posted on 03 Dec 2024 11:24 AM
Thanks both.
What's more peculiar is that if I power of the puck and remove the hdmi cable and reconnect the soundbar indicates dolby surround and the puck setting shows as dolby digital plus! However, when switching the system on next the puck has reverted to pcm stereo.
Should I just set the puck as pass through?
Message posted on 03 Dec 2024 12:30 PM
Message posted on 03 Dec 2024 12:31 PM
I will set pass through and see how it goes.
Message posted on 04 Dec 2024 02:54 PM
Thanks for your help!
That with a wee bit of a change at switch on seems to have stabilised the settings.
Plus it all sounds a lot better!
