5
This discussion topic has been answered Discussion topic: Sky stream remote uses batteries at an alarming rate
This message was authored by: Cr55
I don't know if anybody has the same problem, but my sky stream remote eats batteries for fun.
Every month I have to renew the batteries because they die.
I've got another remote upstairs and the same thing happens.
This message was authored by: Jporch316 Answer
Re: Sky stream remote uses batteries at an alarming rate
@Cr55
There was a bad batch of remotes many months ago ...
I've had 4 remotes for almost 2 years and changed the batteries maybe once in each set
you can request replacement of faulty remotes on this link
Replace remote
https://www.sky.com/help/forms/streaming-tv-remote
@Cr55
Replace remote
@Cr55  My original remote needed a new set of batteries every 3 weeks and I have seen post on the forum of other people whose batteries only lasted a matter of days.  Overall the quality of the remotes is very poor (I'm being polite).  I got a replacement from Sky and that has behaved.
I would simply request a replacement using the link provided by @Jporch316 but in the meantime if you have one available you can use a Sky Q remote until your replacement arrives
Avatar for Cr55
Level 2 icon
Thanks  @Jporch316
I'll be on to sky for a replacement remote.
This message was authored by: CSBisset
I know its an old thread but I'm changing batteries every 2 days 😞
Hi @CSBisset  That is obviously not correct and as you can see from my post above I had a similar issue but in my case the batteries lasted a few weeks.  Have a look at the "Answer" to this thread above posted by @Jporch316 where you will see a link to request a replacement (you will need to sign into your MySky account).
