Discussion topic: Sky stream remote control is no longer working when trying to change volume getting sick of the issu
This message was authored by: Lauren6441
The volume via the sky stream remote is not working it seems issue after issue have rung sky and automated message says call back tomorrow????????.
Re: Sky stream remote control is no longer working when trying to change volume getting sick of the
@Lauren6441 From memory I believe the customer services are open from 8am to 9pm (or maybe 7pm).
Have you tried to pair the remote again? If not give it a try as follows:
  1. Press 7 and 9 together on your Sky remote for three seconds (This resets/clears the remote)
  2. Press 4 and 6 together for three seconds
  3. Press 1 and 3 together for three seconds (bluetooth mode).  A connected message should appear on your screen, press continue and it's all done.
If that doesn't help the links below are to remote troubleshooting guides:
Troubleshooting guide
Remote help
You could also try holding the remote at both ends and giving it a gentle twist as though you were wringing out a cloth.  Even though it sounds an unlikely solution it has got many faulty remotes working again (including my own).
If none of the above help then I would request a replacement at the following link: Streaming TV replacement remote
If you are lucky enough to have one available you can use a Sky Q remote while you wait for a replacement to arrive.
