Discussion topic: Sky stream remote control, are they all the same and work on any puk?
Message posted on 02 Mar 2025 03:10 PM
To explain, I have two rooms that are separated by glass doors/walls. These rooms are both set up with tvs. I have one with sky q and one with free view. This is because if you changed the Chanel in one room the signal would change the other tv.
however, I've seen some info suggesting the stream puks have to be paired with the remote first. Does this sugguest if I get sky stream puks in both rooms they would each be independently paired the remotes wouldn't interfere with each other?
Any other options?!
Message posted on 02 Mar 2025 03:13 PM
Re: Sky stream remote control, are they all the same and work on any puk?
Yes the pucks have independent connectivity between the remote and the puck. They use Bluetooth for communication rather and infrared, hence the pairing process.
MikeAlanR
