06 Aug 2023 07:24 PM
Sky stream remote suddenly not working correctly. Many of the buttons have the wrong function. An example is pressing 1 mutes the tv
06 Aug 2023 07:47 PM
Posted by a Superuser, not a Sky employee. Find out more@Searle2431 this has been reported before check the batteries are in the right way round and not damaged.
06 Aug 2023 10:40 PM
Posted by a Superuser, not a Sky employee. Find out more@Searle2431 try resetting and then pairing the remote again as follows:
There are also some troubleshooting guides for faulty remotes at the following 2 links:
If you are still having issues you will need to contact Sky and request a replacement remote. You can use a Sky Q remote while you wait for a replacement if you have one available.
20 Sep 2023 09:24 AM
I have this exact same problem and tried all the tricks including reset of all equipment, reconnecting remote, twisting remote etc. Please can you replace my remote.
20 Sep 2023 09:25 AM
@peteainsworth wrote:I have this exact same problem and tried all the tricks including reset of all equipment, reconnecting remote, twisting remote etc. Please can you replace my remote.
You'll need to ring Sky to get a replacement.
20 Sep 2023 01:31 PM
Actually others have had their issue resolved on here by being sent a chat link. https://helpforum.sky.com/t5/Glass-Stream-Live/Contact-sky-stream-remote-not-working/m-p/4394007
The phone line has a 40 minute wait at the moment.
20 Sep 2023 01:35 PM
Posted by a Superuser, not a Sky employee. Find out moreI've escalated this to Sky Community Messaging Team who will send you an invitation for an online chat.
The link below explains the procedure
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Keep a look out for the speech chat bubble that will appear on the bottom left of your screen when you are logged onto this forum. When the blue bubble does appear you have 48 hours to respond or it will be automatically closed. Note replies from Sky are not instant so you’ll need to regularly check the chat thread.
20 Sep 2023 02:37 PM
Posted by a Sky employeeThanks for escalating this. We’ve sent an invite to chat.
29 Sep 2024 07:51 PM
Hi. My sky remote has the buttons mixed up. Pressing left on the selection wheel turns the box on/off. None of the other buttons now work.
I have tried to 7&9, 4&6 and 1&3 reset techniques. The remote says it is resetting after 1&3 but the same issue remains.
Can you please send me a new remote.
30 Sep 2024 12:28 PM
@CJRey wrote:Hi. My sky remote has the buttons mixed up. Pressing left on the selection wheel turns the box on/off. None of the other buttons now work.
I have tried to 7&9, 4&6 and 1&3 reset techniques. The remote says it is resetting after 1&3 but the same issue remains.Can you please send me a new remote.
If the reset hasn't worked you could try holding the remote at both ends and giving it a gentle twist as though you were wringing out a towel. This has fixed remotes for a lot of other customers.
If it is still not working have a look at the following guides:
https://www.sky.com/help/articles/remote-control-help-sky-glass
https://www.sky.com/help/home/sky-tv/sky-tv-glass/fixing-a-problem-sky-glass/fixing-sky-glass-remote...
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
30 Sep 2024 09:11 PM
"Wringing the remote out like a towel" astonishingly hasn't worked ...
01 Oct 2024 08:09 AM
Posted by a Superuser, not a Sky employee. Find out more@CJRey That's a shame, it has worked twice for me and the forum is full of posts where it has worked. Your best bet is to contact Sky, explain your issue and ask for a replacement.
