Discussion topic: Sky stream not showing full length of programme
Message posted on 16 May 2025 09:47 PM
Message posted on 16 May 2025 09:52 PM
Re: Sky stream not showing full length of programme
Hi @Alias7
Re the channels sly publish the channel list here: https://www.sky.com/help/articles/tv-channel-list-sky-glass. Sky cannot add channels unilaterally and require an agreement with the broadcaster to add channels to the Glass and Stream EPG. Smaller channels may not be able to meet the cost or technical requirements and therefore decide not to be on the system at this stage.
Re recording you are right, Glass and Stream does not record. There is no hard drive hence no settings. You can check to see if the program is on the My5 app rather than the cloud recorded version, however the only other thing you can do is record the issue to Sky's viewer relations team (email viewerR@sky.uk) who will investigate and feedback. It could be an issue with meta data between channel 5 and Sky etc.
MikeAlanR
Message posted on 16 May 2025 10:03 PM
Hi
Thank you for the email and I will send them an email with the info.
I do wonder if it's an issue with the My5 channel because this channel is the only one that doesn't always let me watch shows I've added to my playlist. I started watching Nashville then all it does now is shows the buffer icon for several mins and this has been like it for months. I contacted My5 directly and they said it could be my tv not updated with the update etc but my TV is brand new and it was all up to date and I did explain that I'm not viewing My5 directly from my TV but via my Sky Stream puck-they never replied back.
Then it happened again a few times with Hawaii 5-0 the new series not the original and that's hit and miss-I press play, it goes from the home screen and shows the My5 icon screen then the buffer icon goes round and round for minutes so I try again every so often.
I'll send all this to sky stream and see if there's anything they can do. I love Sky but if I and a choice of Sky Q and Sky Stream I would have stuck with the Sky Q. There's no Virgin in my area so it's a bit like like it or lump it sort of situation. Lol.
I did check the channels list that show which channels they don't do as I was wanting to watch a craft shopping channel show and it said it was Sky 670 and when I went down my channels I noticed it wasn't there. In fact there's none of the craft/jewellery making shopping channels.
