6
This discussion topic has been answered Discussion topic: Sky stream lip sync issue with Samsung soundbar
This message was authored by: Alibaz
Changed from Sky Q to Sky stream TV today, but I now have a lip sync issue with my Samsung soundbar & on the screen picture. There is no lip sync issue when viewing TV through my LG OLED TV or when viewed on previous Sky Q box. Has anyone else had the same issue & is there a fix for it?
Does anyone know a fix for this?
This message was authored by: Nigelb1972 Answer
Re: Sky stream lip sync issue with Samsung soundbar
HDMI to TV and then arc out to your soundbar?
Try Dolby Digital Plus as the audio setting on the puck and set the TV to pass through.
This message was authored by: Dazzasky
Try changing the sound mode to pass through on the stream box if you haven't already. @Alibaz
Avatar for Alibaz
Thanks for the suggestion. I've tried it, but unfortunately it hasn't fixed the issue.
Are you connecting via spdif or HDMI via Arc or eArc?
Avatar for Alibaz
The connection is via HDMI ARC.
Avatar for Alibaz
Thanks for your suggestion. I have changed the setting to Dolby digital plus & the lip sync problem has been resolved.
Thanks again for your help.
