Discussion topic: Sky stream , honest review
Message posted on 09 Mar 2025 01:09 PM
Re: Sky stream , honest review
Could simply be brief line dropouts .... you wouldnt really notice these on devices that use buffers and I guess it would be more noticeable on a device like sky which is in continual use
Message posted on 09 Mar 2025 01:36 PM
....and given that the software and hardware works reliably for most, it wouldn't appear that they're fundamentally flawed either.
Message posted on 09 Mar 2025 01:56 PM
Still affecting many others as well!!
Message posted on 09 Mar 2025 02:00 PM
That's why I said 'most'.!! How many others, only Sky would have any idea of.
Message posted on 09 Mar 2025 02:33 PM
Same here. Daily issues with lost connection. 3 hours with ISP, no issues - using Netflix via TV with no issues, but via Sky - licky to get 30 mins before freezing. Tried lots of the suggestions - no luck.
Just not fit for purpose - why every other device working but not the puck?? Too easy to blame ISP.
Message posted on 09 Mar 2025 02:39 PM
I think has a lot to do with your isp....when I first got my puck I was using giffgaff (02 network)...and had nothing but trouble with "programme not loading".I was having to reboot about twice a day.....switched to Smarty (3 network) about 4 weeks ago and not had to reboot once
Message posted on 09 Mar 2025 03:54 PM
Adequate and acceptable quality aside, my issue with Sky Stream that not all have is that it is *not* a *premium* product. The hardware may be adequate, but it is absolutely no match for Sky Q with it's smoothness.
I don't get picture in picture all my way through the menu which is also a UX issue (if I'm watching sport and want to check something else for e.g.)
I still hope they will release a premium hardware option down the line when some lessons have been learnt from the puck.
Message posted on 09 Mar 2025 03:59 PM - last edited: 09 Mar 2025 04:00 PM
@pressandgo @OKcambridge You both spot on. Blame and responsibility is with Sky to fix, no one else and @Mark39 misread your post sorry
Message posted on 09 Mar 2025 05:50 PM
Thanks for the summary- can you fast forward to avoid the adds as you can with sky q
Message posted on 09 Mar 2025 05:53 PM
@Tony+Crane Yes, if you have the ad skipping package. That package also lets you skip ads on Channel 4 app and ITVX so it's pretty good value.
Message posted on 09 Mar 2025 06:51 PM
Completely agree with this, sky stream has much better picture quality and sound quality with Dolby Atmos than Sky Q. There are a few quirks to iron out like the sound on mine doesn't always work. But a quick off and on fixes that. Also the puck can be hidden away out of sight. Over all much better than Q. Mine is hard wired on 900mbps full fiber which may make a difference.
Message posted on 09 Apr 2025 09:34 PM
Looks like this might be my only option as a new customer, as they don't seem to offer Sky Q to new customers anymore. In general I just don't like or trust streaming. If I get it and am not happy is there any way I can revert to Sky Q? Finally moving into my own place but used my parents' Sky Q for years and it's been near on perfect, but not sure about this at all.
Message posted on 09 Apr 2025 09:37 PM - last edited: 09 Apr 2025 09:38 PM
As far as we know Q is still available, but it does now seem to have disappeared from the Sky website drop-down menu for Television. Sky has publicly stated that the vast majority of new subscribers are opting for Glass/Stream.
Message posted on 09 Apr 2025 09:39 PM
Any idea how I could get Q? Phone call possibly?
Message posted on 09 Apr 2025 10:10 PM
@SillyPoint wrote:Any idea how I could get Q? Phone call possibly?
Yes phone call would be the best option
