Discussion topic: Sky stream freezing or waiting for signal
Message posted on 19 Feb 2024 05:20 PM
Sky stream freezing and losing signal. I've had broadband checked which is full fibre 70mb
Message posted on 19 Feb 2024 05:22 PM
							Re: Sky stream freezing or waiting for signal
@stevehambrecht Speed of the line isn't all, what is your wifi speed like as this sounds like the issue here.
Message posted on 19 Feb 2024 05:46 PM
@stevehambrecht you can check the speed from the puck by opening the Netflix app, going to get help and then check your network. It's worth doing this several times particularly when you are seeing the issue.
Also worth testing by connecting via Ethernet cable instead of WiFi. When testing this you should ensure you go into the pucks settings and disable the WiFi otherwise your testing may be invalidated as the puck may start switching between WiFi and Ethernet.
Message posted on 19 Feb 2024 06:17 PM
Hopefully Sky will implement their own network check like other devices?
