Discussion topic: Sky stream consistently has lost internet connection everytime I turn on
This message was authored by: dj12344
This has been going on for months I have community fibre broadband and it will be ok on on other devices. Just sky I have to reboot the connection every time to watch tv. Very annoying. It generally lasts then until I switch off
This message was authored by: Padam_Padam
Re: Sky stream consistently has lost internet connection everytime I turn on
I have Community Fibre and never had any trouble with my Stream puck. I tended to use ethernet rather than WiFi. How are you connecting? Do you have network standby turned on in the settings?
Avatar for dj12344
I connect via wifi and cant do ethernet. I am not sure what network standby is?
Its a mode in the Puck's network settings, it best to ensure this is ON which ensures that the puck maintains a network connection. If its off it can sometimes take a while for the puck to connection to the internet when its turn on out of standby mode.
If that mode is already on then it does sound like the strenght and stability of the WIFI network could be the issue.
@dj12344 by "switch off" do you mean....
Standby
OR
Power off at the plug?
This message was authored by: 2464BM
This is the same with my two puck devices I have, more recently when it starts up sometimes the programme starts then within seconds an error message flashes up to say that "wait till programme loads"
Avatar for dj12344
Hi looked in settings/network and no option like that in either network connection or advanced settings
@dj12344 Strangely it is not in Network Settings.  You will find it in the Settings > Start up and Standby menu.  Just make sure Networked Standby Mode is turned ON which stops your puck losing the network connection when it goes into standby.
