Discussion topic: Sky stream blacks in and out during adverts
Message posted on 01 Aug 2025 05:45 PM
Re: Sky stream blacks in and out during adverts
Are you still having issues, ive been a customer for two weeks. Screen would go blaclk and back on several times on multiple channels but only during ad breaks. I disable the ad smart personalisation through my sky app and it fixed the issue for a week. Now its back with no sign of a fix. Call sky, they say there aware of the issue but no time frame on a fix, should I just cancel whilst in cooling off period its so annoying don't want to be stuck with this.
Message posted on 01 Aug 2025 06:30 PM
I haven't noticed the problem since I said I had turned off the AdSmart setting. I must admit I haven't watched the affected channels quite as much but I don't recall seeing the issue at all in the last few days.
Message posted on 04 Aug 2025 10:07 PM
Hi. We are also having the same issue and it's absolutely linked to channels using sky AdSmart.
ive also turned off the personalized adverts to see if this helps.
