5
This discussion topic has been answered Discussion topic: Sky puck shows sky logo on start up then TV goes blank ......sky light goes out on box
This message was authored by: cgwiz2001
Tried rebooting changing HDMI settings etc tna....any ideas anyone?
This message was authored by: mikealanr Answer
Re: Sky puck shows sky logo on start up then TV goes blank ......sky light goes out on box
Hi @cgwiz2001
It sounds very much like the outage issue the other week. Have you recovered the puck.as per Sky's instructions? https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on
MikeAlanR
Hi @cgwiz2001
MikeAlanR
This message was authored by: Jporch316
If @mikealanr  suggestion doesn't work then you will need to contact sky for troubleshooting as it may have developed a fault
Avatar for cgwiz2001
Many thanks for the advise..... ill certainly try this in the morning.
will repost the outcome.
Pete
This worked....the puck went into a factory reset but ultimately resumed normal operation once I  re registered it as per the onscreen instructions.
Thanks again
This message was authored by: Frances4
My puck gets stuck on white light flashing
