4
Discussion topic: Sky puck shows sky logo on start up then TV goes blank ......sky light goes out on box
This message was authored by cgwiz2001 This message was authored by: cgwiz2001
Tried rebooting changing HDMI settings etc tna....any ideas anyone?
This message was authored by mikealanr This message was authored by: mikealanr Answer
Re: Sky puck shows sky logo on start up then TV goes blank ......sky light goes out on box
Hi @cgwiz2001
It sounds very much like the outage issue the other week. Have you recovered the puck.as per Sky's instructions? https://www.sky.com/help/articles/sky-glass-stream-wont-turn-on
MikeAlanR
65” Sky Glass ocean blue, Sky Live, 4 streaming pucks and EE FTTP Busiest Home (circa 1.6 Gbps download). Former Sky Q, Sky+ HD and Sky+ customer.
Hi @cgwiz2001
MikeAlanR
This message was authored by Jporch316 This message was authored by: Jporch316
If @mikealanr  suggestion doesn't work then you will need to contact sky for troubleshooting as it may have developed a fault
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
cgwiz2001
Many thanks for the advise..... ill certainly try this in the morning.
will repost the outcome.
Pete
cgwiz2001
This worked....the puck went into a factory reset but ultimately resumed normal operation once I  re registered it as per the onscreen instructions.
Thanks again
