1
This discussion topic has been answered Discussion topic: Sky puck doesn’t work following a power cut
This message was authored by: ClareHubble
When you turn on the power to the puck it goes through the process of white light then flashing coloured lights then after a few minutes goes to off. The remote has no effect.
This message was authored by: mikealanr Answer
Re: Sky puck doesn’t work following a power cut
Hi @ClareHubble
Try the recovery process. Step 4 on this knowledge article:
https://www.sky.com/help/articles/power-issue-help-sky-glass-sky-stream-puck
If that doesn't work, you will need to speak to Sky customer service forms replacement (we are fellow subscribers here).
MikeAlanR
Hi @ClareHubble
MikeAlanR
