27 Mar 2024 05:07 PM
27 Mar 2024 06:04 PM
@Ron1979 wrote:
My sky puck is starting up, the white light starts flashing and the word sky is on my TV then it comes up error msg weak or no signal. Anyone any ideas?
That kind of message is usually when a TV is looking for Freeview reception via an aerial, not for a signal from an HDMI source.
Is your TV perhaps defaulting to its internal Freeview tuner on startup and you don't have an aerial attached? Try re-selecting the HDMI input you have the Stream puck attached to using your TV's remote controller (not the Stream remote).
