16
This discussion topic has been answered Discussion topic: Sky puck ??? Should be sky **ck
This message was authored by: Hunter2660
Message posted on 30 Aug 2025 12:40 PM
Re: Sky puck ??? Should be sky **ck
What isn't discussed a lot is routers. Unfortunately most isp's just use cheap basic routers which can cause issues with Stream. It's a bit of a lottery and not easy to work out why some people have a lot of issues and the rest of us don't. In my case I've had Glass on wi-fi and Stream on ethernet for 18 months and they're both as solid as a rock. I can only suggest that if Stream doesn't work for you, go down the Now route.
This message was authored by: Ipredikta
Message posted on 30 Aug 2025 01:06 PM
Yup, that's the route I'm looking at.
