Discussion topic: Sky keeps going off on my sky puck in my living room
This message was authored by: Willowbaby2020
My sky either keeps going off completely every 30-60 minutes or goes off and says "technical issue and blank screen, I unplug cables and it comes back on until the next time
This message was authored by: peter-marlow+1966
Re: Sky keeps going off on my sky puck in my living room
How is your  puck connected to the Internet, if you  can connect it  with an ethernet cable  it is more stable than a wifi  signal. Also what speed  is your broadband, and what other  devices do you have, connected to the Internet?
P c marlow
This message was authored by: Stephen+Mourton
@Willowbaby2020    As @peter-marlow+1966 has said the main reason these problems crop up is either internet speed, or obstruction to the signal.  If you are not using an Ethernet cable does your router have a clear line of sight to your puck and also are sure neither have objects too close to them.
