Discussion topic: Sky keeps freezing and won’t go past 20% loading
This message was authored by holties10 This message was authored by: holties10
When watching something on the TV, The screen keeps going black and will not let me watch anything When I go to watch something, it only downloads 20% and stops
This message was authored by Padam_Padam This message was authored by: Padam_Padam
Re: Sky keeps freezing and won’t go past 20% loading
Nothing downloads on Sky Stream - everything streams 'live' from a server.
Your issue would indicate a problem with the network connection being received by your Stream puck. What is your broadband speed? To find out what the puck is receiving you need to open the Netflix app, navigate to the get help menu and run a network check.
Ideally you want a bare minimum of 30Mbps for the puck to function.
This message was authored by Fothergill1 This message was authored by: Fothergill1
@holties10 You don't specifically mention Netflix but if the problem occurs when loading Netflix programmes this has been reported in the past but I have not seen similar posts recently.
The easy way to overcome the problem is to go to Netflix "Get Help" and select reload Netflix.  Once it has refreshed you should be able to watch you selected programme.
If my post has solved your issue please mark as an "Answer"
