22 Aug 2024 01:30 PM
We add issues last night tv channels going off air saying you have technical issues with the channel then Broadband connection showing as offline not connected all over the place really
22 Aug 2024 02:45 PM - last edited: 23 Aug 2024 09:28 AM by Daniel-F
@GD1 (Removed)
Stream was sold originally as requiring a minimum broadband speed of 10 Mbps and it certainly was the case when I BOUGHT my puck.
It actually uses around 8 Mbps of bandwidth in HD according to many who have tested it, me included.
The increase in recommended speed was nothing to do with a change in technology but backside covering by Sky to allow for a typical home environment.
What is does need is a stable stream which is not always the case over WiFi irrespective of the home's incoming internet connection speed.
Moderator note: Removed inappropriate remarks
22 Aug 2024 05:13 PM
I also read on screen the broadband needs refreshing on homepage so I pressed the home button via controller and it seems fine wasn't sure if it was the hub needs restarting
22 Aug 2024 05:14 PM
Cheers for that info 👍 👌
