Discussion topic: Sky Stream
This message was authored by Emma262 This message was authored by: Emma262
Sky Stream
Hello, I have a large house with 6 bedrooms, currently have 1 main sky box plus 3 mini boxes. Thinking of changing to sky stream so no dish will be required. Not sure if will work though as 2 active broadband lines in the house (due to size of house etc). Can you connect sky stream boxes on one account to 2 different broadbands? Or could you have more than one account per household (not possible with a dish) also can you record on sky stream??
Re: Sky Stream
@Emma262 You can only have 1 account per address, there mya be issues using the 2 different brodband lines at the same time.
However you can have up to 6 pucks assuming your broadband speed is up to the job?
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
