Discussion topic: Sky Stream
This message was authored by: Patbryz
Sky Stream
I am changing from Virgin to Sky Stream , can I use the external Virgin box to thread the Openreach cables needed for Sky TY
This message was authored by: martswain
Re: Sky Stream
If you are getting full fibre it will be a completely different installation to your existing Virgin setup.
The only thing they may use is the same hole in the wall to bring the fibre cable into your home.
You will then have a new termination point (ONT)
Discuss where you want this with the installer on the day.
Avatar for Patbryz
Re: Sky Stream
Completely answered the the question I couldn't explain properly,BUT THROUGH THE ORIGINAL HOLE USED BY VIRGIN IS WHAT I WANTED ..Big Thanks.
Re: Sky Stream
@Patbryz
Sky Stream doesn't use any external cables.  If you placed an order for Sky Broadband at the same time as ordering Stream, that's separate process.
Whether an Openreach installer is prepared to use an existing opening is up to them: I suspect they won't remove Virgin cabling.
