This discussion topic has been answered Discussion topic: Sky Stream
Message posted on 29 Feb 2024 09:26 PM
I like recording the football on BT and Sky Sports on Sky Q are all the matches available after broadcast?and for how long?
Message posted on 29 Feb 2024 09:37 PM - last edited: 29 Feb 2024 09:39 PM
Hi @Football246
There isn't a definite answer for this. It depends. If the content is on a broadcaster that has a catch up service (i.e BBC iPlayer or ITVX) it's at the mercy of that broadcaster to add it to their service. Can be between minutes or hours.
With Sky sports stuff or broadcasters without a catch-up service, sky's cloud recording can be used and it's available immediately.
See: https://www.sky.com/help/articles/your-playlist-and-tv-guide-sky-glass
Under "shows not showing in your playlist" it states:
Shows saved for 12 months
Most shows and movies in your Playlist will be saved for 12 months. Some that are available through a TV app, like Netflix or ITVX, might not be available for that long, as they have different contractual agreements.
For example, most programmes from BBC iPlayer are available for 12 months. But some, like Match of the Day or the News, aren't available for as long.
Sky Sports and TNT content is available for 12 months according to the relevant sections in that article.
Hope this helps
MikeAlanR
Hi @Football246
Hope this helps
MikeAlanR
Message posted on 29 Feb 2024 10:05 PM
Re: Sky Stream
Thank You very much for your help
