Discussion topic: Sky Stream will not accept my pin. I tap it in but it just keeps asking for the pin
Message posted on 03 Oct 2025 10:22 PM
System will not accept my pin. Just repeatedly keeps asking for it
Message posted on 03 Oct 2025 11:22 PM
							Re: Sky Stream will not accept my pin. I tap it in but it just keeps asking for the pin
Hi @Southy01 unless you have changed your pin the default is the last 4 numbers of your phone number registered with Sky.
Try this and see if it works.
Message posted on 04 Oct 2025 09:36 AM
a thanks but my pun is correct. I keep entering it and it just keeps asking for it.
if the Pin was wrong, it would only give me 3 chances. I've tied 20+ times!
Message posted on 04 Oct 2025 11:34 AM
Hi again @Southy01 Have you tried rebooting your puck in case it is a software glitch?
To do this go to Settings > System Management > Resets & Updates > Restart device. It takes a couple of minutes to completely reboot and you will have a blank screen for a couple of minutes before the Sky logo appears.
Message posted on 04 Oct 2025 01:30 PM
Is this on initial puck setup or when trying to watch a show ?
if it's on setup try pulling the power lead when you see the pin screen and it should skip it on the next run through
