Discussion topic: Sky Stream stops working when physically connecting a secondary device to the broadband router
Message posted on 15 Jan 2024 05:58 PM
My Sky Stream works perfectly fine until I physically connect my CCTV system via LAN to the broadband router. I am connecting in order to view cameras away from home. Sky Stream stops working saying there is no signal but WiFi is working perfectly fine for other connected devices. Any ideas how to resolve?
Message posted on 15 Jan 2024 06:00 PM
Re: Sky Stream stops working when physically connecting a secondary device to the broadband router
Potentially the cctv may be trying to use the same ip address as sky stream? Maybe worth trying to give then system a fixed alternative ip address in then settings that's within your internal range
Message posted on 15 Jan 2024 06:04 PM
So a common misunderstanding is that because it's fine on another device it will be fine on Sky Stream or Glass is unfortunately incorrect.
These services are unique in that when on they have a permanent connection to Sky servers and thus require a constant 30 Mbps connection. What seemingly happens is that if the broadband speed the stream or glass gets falls under the minimum recommended of 25-30 Mbps it seems to crash the stream puck until it's rebooted. A number of customers have this issue particularly when connecting glass or stream via WIFI as if the WIFI strength drops for a few seconds, and affects the speed the unit it able it get, it essentially crashes it.
In your situation it could be that the CCTV device is taking the bandwidth below the recommended 30 Mbps. It's also possible it's just a WiFi strength issue and connecting the puck via Ethernet and disabling the WiFi in the pucks settings will also resolve this. I can to do a similar thing with my Sky stream and switch it from WiFi to Ethernet.
Message posted on 15 Jan 2024 06:10 PM
Good point - cctv apps do have a high bandwidth use normally especially if the cameras are hd or 4k ,......
Message posted on 19 Jan 2024 02:13 PM
Just checked my broadband speed and its 151mbps , so I don't believe this is the issue, but appreciate this will vary. Also the CCTV system worked fine with previous versions of Sky (Plus & Q) so I'm not sure the IP address is the issue either. Any other suggestions would bve appreciated - many thanks
Message posted on 19 Jan 2024 02:31 PM
@rosss wrote:Just checked my broadband speed and its 151mbps , so I don't believe this is the issue, but appreciate this will vary. Also the CCTV system worked fine with previous versions of Sky (Plus & Q) so I'm not sure the IP address is the issue either. Any other suggestions would bve appreciated - many thanks
Did you check the broadband speed actually on the puck? To do this open the Netflix app, navigate to the get help menu and run a network check. This will tell you the actual speed being received by the puck.
