Discussion topic: Sky Stream, locks up with no picture, disconnect power for 30 mins, put back on and the picture and
This message was authored by: MP18
Sky stream, keeps locking up, and going to blank scream, sometimes says loading. Turned off box and waited 30 mins
When switched back on picture and sound are not synchronised so have to start again  been happening all week  now becoming a little annoying.
Re: Sky Stream, locks up with no picture, disconnect power for 30 mins, put back on and the picture
Hi @MP18
How's is your Puck connected to the internet and what is your broadband speed? The recommended minimum broadband speed of 25Mbps. Or 30Mbps if you add an extra Sky Stream puck or to watch in UHD.
Connecting via ethernet and turning off WiFi may provide stability. You can check what speed you are getting at your Sky Stream Puck by opening Netflix scrolling down to notifications and then across to help. In the menu go to check your network.
Has the Puck been working previously? Anything changed in your setup?
MikeAlanR
Avatar for MP18
Hi Alan, nothing changed with set up, BB @ 35M, tried contacting Sky to no avail. Noticed picture has a blip, repeating what was last shown, then voice is out by 4/5 seconds...only way to regain sync, is by turning everything off and twiddling thumbs for 5 mins, dead annoying when watching sport. Oh well back to trying to talk to someone about it.....
@MP18 Have you tried connecting via Ethernet as suggested in the above post by @mikealanr ?
