272
Discussion topic: Sky Stream - Remote won’t turn on any of my pucks!
Locked
This message was authored by G+Champion This message was authored by: G+Champion
Re: Sky Stream - Remote won’t turn on any of my pucks!
Ill be trying this on my two in the next hour or so. Thanks for this.
Will report back any changes.
This message was authored by B19BOL This message was authored by: B19BOL
Call me a sceptic but I am 😀
Not a good start when 1 & 3 did not work and I had to press 4 & 6 first before it would do so.
I have 3 to do this on, will be trying on one at a time.
1. Is there no way to force a quicker update rather than having to wait overnight to see?
2. How do we know if an update has been done?
We will see.
This message was authored by highr This message was authored by: highr
Thanks @KevNewMedia. I will also try this shortly and report back.
This message was authored by WC1989 This message was authored by: WC1989
It's working, got too eager to wait till the morning. I left it on while I went to Tesco, which was easily 50 mins. It turned itself onto stanby while I was out, and hallelujah the remote turns on the puck while in Bluetooth mode now.
This message was authored by Kempston This message was authored by: Kempston
Worked for me too. Leaving it overnight isn't required, once the second power cycle is complete, it should be updated and working. Turn the puck off for 10 minutes to make sure it's in full standby, block the IR transmitter to be certain, then power the puck on.
This message was authored by Jporch316 This message was authored by: Jporch316
Glad the fix is working for you all ....
43inch and 55 inch Sky Glass & 3 Pucks on virgin media M350 hub 5x. 4 x sky mobile sims. Pretend guitar aficionado .. rock on!
Two of my three restarted as instructed. Both now working rapid on and off via BT.
If you look in system management, build version, it now says software update in progress on the two ive restarted. QS024.012.00P
All good It would seem. Thanks.
This message was authored by kea+hong This message was authored by: kea+hong
Early testing with 3 of my pucks seems to show that the fix works. Thank you.
This message was authored by MarkGoldsmith This message was authored by: MarkGoldsmith
That software update message is a bit misleading. Its a bug it always says that unfortunately 😀. Although i believe that maybe getting fixed in the next software update.
Sky Stream user. Former Sky+ HD and Sky Broadband customer
NOT a Sky Employee
This message was authored by Fothergill1 This message was authored by: Fothergill1
@G+Champion Just to confirm the post form @MarkGoldsmith. I am on the new QS025 update and the bug he refers to has been fixed.
@MarkGoldsmith Are you still on QS024?
If my post has solved your issue please mark as an "Answer"
Thanks Fotgergill1.
Does that mean that I will get the latest update of 025 tgen, as its in progress now on the two pucks?
@G+Champion wrote:
Thanks Fotgergill1.
The updates are rolled out in batches ..... it's pot luck if you get it in one of the first batches or one of the following batches
@Fothergill1 although working fine now, mine still says QS024.012.00P "Software Update in Progress"
@G+Champion Unfortunately the fact it says it is updating means nothing as that is the bug.  It always says that if you highlight the build version.  However the good news is the new QS025.011.00P update is starting to roll out.  My stream puck received it last night. 😀
EDIT - Just to avoid confusion the bug fix for turning on your puck using bluetooth is seperate to the QS025 update.
What you are referring to is the software version of the puck which is different to the remote firmware.
As previously mentioned that message is always there as it's a bug which is fixed in QS25.
NOT a Sky Employee
Locked
