Discussion topic: Sky Stream Puck remote does not sync with Sony Bravia TV
This message was authored by: TG2823
Re: Sky Stream Puck remote does not sync with Sony Bravia TV
And the HDMI control is set to ON?
Also if you go to your TV settings...
Channels & Inputs > External inputs > HDMI signal format
what is the format selected for the HDMI that the puck is connected to?
Avatar for APO84
Level 2 icon
This message was authored by: APO84
Enhanced they are all set to but we're on basic option
By basic I assume the standard form or do you mean the enhanced form?
On my TV.... HMDI 3 & 4 let you set it to Ehanced format ( Dolby  Vision) and move the cable connected to the puck the HDMI number you  choose
also are you using the cable that Sky provided? If not I suggest you do..
I've asked a couple of times is HDMI  control set to ON.... is it....
if none of this works I think I've run out of items you can check
Avatar for APO84
Level 2 icon
Still no response from Sky 😞
