Discussion topic: Sky Stream Puck remote does not sync with Sony Bravia TV
Message posted on 02 Jun 2025 05:44 PM
Re: Sky Stream Puck remote does not sync with Sony Bravia TV
Is Sky ever going to contact me to assist with this problem ? Heard nothing for months and others have the same issue.
Message posted on 02 Jun 2025 05:45 PM
Sky just never respond unfortunately 😞
Message posted on 02 Jun 2025 06:28 PM
Quick to take our money or up the prices - but not able to turn the TV up???
Message posted on 03 Jun 2025 05:56 AM
Message posted on 03 Jun 2025 08:17 AM
Hi there! Thank you for escalating this. We have sent an invite to @APO84.
Message posted on 05 Jun 2025 06:47 PM
Hi, I received a new remote today and re-tested and volume does still not work.
went through the 32 options again and still the same issue.
Message posted on 18 Jun 2025 07:53 PM
Any new ideas on how to fix as new remote did not make any difference ?
Message posted on 02 Jul 2025 04:42 PM
I have exactly the same problem for a Sony Bravia TV...
But if you don't know already...... once you get to the end of the first 32.... just press no to everything...... it gives you the chance to pick your specific brand and TV model number... it does not help the problem but at least you know you have the right TV...
- Still only Switches off the puck, not TV,
- volume control works
- if TV and puck are off switches both TV & puck on
Message posted on 02 Jul 2025 04:47 PM
Message posted on 02 Jul 2025 05:42 PM
I have a fix.... but you'll have to use the Sony remote to switch off your tv / puck.... volume, switch on can be done by the puck remote
- On Sony tv go to settings
- Channels & Inputs
- External inputs
- Bravia Sync settings
- Bravia sync control, auto devices off & Auto TV on all set to ON
- Go to Bravia Sync device list
- You should see all your HDMI devices connected to HDMI
- Make sure the puck is on so you can see it.... but it works for all other connected devices too
- It will show on the HDMI number it is connected
- Press ENABLE
- Come out of settings
- Now by pressing the TV power button any connected HDMI will turn off with the TV
Message posted on 02 Jul 2025 06:47 PM
Done this and still not able to change volume or turn TV off
Message posted on 02 Jul 2025 07:04 PM
@Dazzasky are you able to advise on this issue? It's been 8 months and still no resolution
Message posted on 02 Jul 2025 09:48 PM
Have you tried to find your exact model using the remote
Message posted on 02 Jul 2025 09:57 PM
On the puck
You should be able to do this after you have just flicked through the first 32 saying no...
tben it gives you the option to find the manufacturer &model yourself
Make sure you have turned on HDMI control in startup and standby first before you go to connected devices and selecting your sky remote
Message posted on 02 Jul 2025 10:50 PM
Yes, it's there but still nothing to connect the sound or switch off using sky remote only
