Discussion topic: Sky Stream Puck Saying "No Signal" after Sky logo?
Message posted on 16 Mar 2025 08:54 PM
Hey!
So, my Sky Stream puck has stopped working?!
It was working perfectly fine, and was switched off whilst I was out of the house.
When I came back, I powered up my Sky Stream puck, the black and white Sky logo appeared, and then my TV says "No Signal".
I've tried multiple HDMI leads, multiple ports, and done the reset method, all to no avail. I know it is sending an HDMI Signal, because I see the Sky logo, but nothing else.
The white light remains on solid, and I can use the remote to put it in standby, but there's just nothing.
Message posted on 16 Mar 2025 08:57 PM
Re: Sky Stream Puck Saying "No Signal" after Sky logo?
I realise this isn't in the right place, but I wasn't given an option to choose where it posted.
Message posted on 16 Mar 2025 10:03 PM
Hi @natestnate
Try powering it off at the mains for at least 5 minutes and turning it back on.
If it still doesn't work, step though all the steps outlined here: https://www.sky.com/help/articles/power-issue-help-sky-glass-sky-stream-puck
Including undertaking a full recovery of your puck. If that doesn't work you will need to speak to Sky and arrange a replacement.
MikeAlanR
Message posted on 16 Mar 2025 10:29 PM
Your problem as mentioned above is usually cured by performing the recovery procedure as detailed here in step 4
Message posted on 16 Mar 2025 10:34 PM
Thank you both for the replies, but I've followed the recovery process multiple times.
I did say that I had tried the recovery process, and all other steps advised in the guide you both posted, but nothing had worked.
It looks like I'll need a replacement. I've only had it for 6 days, and it hasn't worked for 3 of them. 😞
Message posted on 16 Mar 2025 10:43 PM
I've escalated this to Sky and they should be in touch with you soon about it.
Look out for a message from Sky on your email and Sky Community private messages.
Look out for the blue chat bubble within your Sky community.
More about an escalation here;
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Message posted on 17 Mar 2025 01:00 AM
Thanks!
I'll be giving them a call in the morning, but I just wondered if there were any wizards in here that new the secret workaround.
I appreciate all the help.
Message posted on 17 Mar 2025 08:51 AM
Thanks for escalating this. We’ve sent @natestnate an invite to chat.
