Discussion topic: Sky Stream Puck Freezes and switches off every day
Message posted on 21 Aug 2025 09:24 PM
I have 2 Sky Stream Pucks. 1 is fine, the other freezes and switches itself off multiple times per day.
I have checked the broadband connection multiple times and it is 140mbs+
I am really regretting moving to Sky Stream.
I have followed all instructions about location of pucks, unplugging and staring again and nothing seems to work.
Any ideas what's wrong?
Thanks.
Message posted on 21 Aug 2025 09:35 PM
Re: Sky Stream Puck Freezes and switches off every day
Have you swapped pucks to see if the problem follows the puck that has issues. If so it's probably a dodgy puck, if not it's the location that is causing you problems. The pucks need a strong and stable signal, as well as a good speed.
Message posted on 21 Aug 2025 09:41 PM
Hi. Yes, I have swapped pucks and the good one works wherever it is and the poor one is still poor.
Thanks.
Message posted on 21 Aug 2025 09:42 PM
Then it means a call to Sky to get it replaced I'm afraid.
Message posted on 21 Aug 2025 10:00 PM
Tried that a few time and stay on hold too long. Was hoping there was something I was missing 😞
Thanks though.
