Discussion topic: Sky Stream - Paramount+
This message was authored by DisplayNameTaken This message was authored by: DisplayNameTaken
Paramount+ has stopped working on the Sky Stream. I've been in contact with Sky who said to speak with Paramount and have spoken to Paramount who said and I quote
"Please be informed that we are only available to Sky Glass and Q and we do not support Sky Stream."
The problem is whenever you stream it just does the spinning wheel (buffering) and never actually starts the show or displays an error, just spins forever.
Every other app is working, no issues with any channels or applications just Paramount+. The only way I've got it to work again was to factory reset the puck and it worked for a few hours and then died again, I'm not going to reset the puck again.
Paramount+ is working on my laptop and mobile on the same network so it's nothing to do with my network configuration.
Has anyone got any ideas or suggestions  short of cancelling Sky Cinema and Paramount+?
This message was authored by bayardm This message was authored by: bayardm
Re: Sky Stream - Paramount+
I don't know if a puck, supplied when I got Glass, is the same device supplied with Sky Stream but Paramount+ works  ok for me on our spare tv.
Sky Glass 43” stand mount, Wi-fi, 1 puck, ethernet from Bt disc.
Sky Ultimate and whole home, Diamond VIP User
BT Hybrid FTTC, BT Smart Hub 2 + 1 disc
This message was authored by 82bit This message was authored by: 82bit
Yes this seems to be broken currently. Was working the other day on my Stream puck. Now just endlessly spins.
you'd be kinda annoyed if you'd payed for this and used it solely on Sky Stream, and now they're saying it's unsupported. Which begs the question - why does the app appear in the app rail if it's now unsupported? Weird.
Sky Glass 65” with Sky Live
Sky Glass 43” with Sky Live
Sky Stream Puck + Sky Soundbox
Sky Stream Puck x3
BT FTTP:
↓920Mbps
↑110Mbps
DisplayNameTaken
Glad to hear it's not just me ! Not impressed by the response from Sky or Paramount !
This message was authored by Paul+Boland This message was authored by: Paul+Boland
Paramount+ app working ok on my Sky Glass and Sky Stream Puck
Just tested in the last hour 4 different Movies and TV Shows  as in played for about 10 min of each stream there has been no buffering once Film or TV Show starts actual video playback
Both my Sky Glass and Sky Stream pucks are connected by Wired Ethernet and I have a very stable broadband connection which has no latency issues
Is there any paticular content on Paramount+ that some users having as I don't have time to test every movie or show on Paramount+
Are your Sky Glass or Sky Stream pucks connected by Wifi or Wired Ethernet and what download and upload speed do you have and what type of broadband connection you have as in is it Fiber or Landline or Mobile broadband
And how many devices are using your broadband connection same time
Have you tested your broadband connection that you get from your router for latency and packet loss
Have gigabit FTTP with low latency. Wired Ethernet connection. Get a spinner on all content on Paramount+.
Sky Stream Puck x3
BT FTTP:
↓920Mbps
↑110Mbps
DisplayNameTaken
Hi
It won't play anything, I'm  on Fibre 900Mb and eveyrthing else works fine, just Paramount+ is broken.
@82bit
I have no buffering with Paramount+ app on Sky Glass or Sky Stream Puck
All content I tested today is playing no issues
It's not buffering, it just fails to load anything. I'll try rebooting the puck at the mains, when the snooker is finished!
Sky Stream Puck x3
BT FTTP:
↓920Mbps
↑110Mbps
@82bit
I watching Mission Impossible - Fallout right now on Paramount + App on Sky Stream Puck no issues
DisplayNameTaken
Only thing I could do to get it to work again was factory reset, but then it failed again.
It's not buffering agree, it's the buffering spinning wheel that get's displayed and nothing loads and then the app doesn't respond you have to just close it but going to another app or channel.
Pulled the plug and seems to be working now. One of the many bugs with Stream, I guess?
Sky Stream Puck x3
BT FTTP:
↓920Mbps
↑110Mbps
DisplayNameTaken
Just to follow up I found the issue was my Firewalla family safety was preventing Paramount+ and only Paramount+ from streaming, all other services fine. I've fed back to Paramount+ that it was just hanging and they should time out or give a useful error message.
I put the Sky Stream on a dedicated port with no filtering and smart rules giving it priority over all other traffic and its working better then it ever has.
