15 Feb 2024 10:51 AM - last edited: 15 Feb 2024 01:02 PM by KevNewMedia
I'm still having problems. We have new TV's and new pucks delivered about a week ago. They will only start with IR, and then the bluetooth is fine. We have one TV, unfortunately the best one, which has the TV and sound bar mounted to a chimney breast and the puck plus all the wiring subtly concealed just inside the chimney. One of the attractions of Stream was the bluetooth remote connectivity. It is so naff right now as I have to aim the remote up the chimney and wave it around a bit to turn the puck on. After that bluetooth works fine. I have tried to follow the instructions in this thread twice now, the remote firmware verion is 5103.4.2 but it will still only start with IR.
Moderator note: Changed title to reflect topic more.
01 May 2024 03:47 PM
Posted by a Sky employeeHi Everyone
Can I start by apologising profusely for the delay in being able to resolve this problem.
Whilst the problem is still under investigation and I can't say whether this will help, there has recently been a firmware update for everyone's stream to QS027.508.00P. If you've tried this after 26/4/24, and it hasn't worked, there's no need to try this.
I will be marking this post as answered, so that the most up-to-date information is provided for everyone, and you don't need to read the entire thread. As soon as I have more information/resolution, I will let everyone know.
14 Feb 2024 08:47 AM
After the upgrade mine power on with IR but Bluetooth works fine after that - I'm ok with this TBH, I don't need to hide them away.
14 Feb 2024 11:11 AM
I'd be interested to know why mine won't wake the pucks up with bluetooth but now will with IR (and then Bluetooth does work) - they couldn't do either before. As I've said it's not a deal breaker for me but if others have followed the same process and the pucks WILL now wake up with BT I wonder why mine won't.
14 Feb 2024 08:25 PM
Mine now says it's on firmware 5103.4.2 I've reset & repaired the remote many times restarted the puck as instructed but still no luck. It will only power on via IR 🙄🤔
14 Feb 2024 08:28 PM
did you try press 4 & 6 for 3 seconds before then pressing 1 & 3 to connect the remote?
14 Feb 2024 08:31 PM
I have, tried 7 & 9 then 1 & 3, 4 & 6 then 1 & 3 but it's still not having it. Will have another try then give up until tomorrow 😂
14 Feb 2024 08:52 PM
I am also still haing problems. On the IP06 it connects but not to volume and then loses within a minute of use - keep trying to repeat but no success. Also had problems with the older IP04 where the remote control stopped working completely - tried all the combinations to try and reset but to no avail - sky are sending me out a replacement remote for that one which will hopefully work. Will continue to try again tomorrow to fix the IP06 as per the instructions
15 Feb 2024 01:56 PM
Mine is the same. Tried all the different resets, but will only turn on via IR. After that Bluetooth is fine.
15 Feb 2024 05:45 PM
There is also another thread on this here (no resolution):
https://helpforum.sky.com/t5/Sky-Stream/Power-on-Stream-with-puck-out-of-sight/td-p/4338811
15 Feb 2024 07:31 PM
Even after doing the remote firmware update as per the previous thread I still can't switch on the puck with Bluetooth, only IR.
Once the pick is on then Bluetooth works fine for voice searching etc.
15 Feb 2024 07:58 PM
@Spud132 wrote:Even after doing the remote firmware update as per the previous thread I still can't switch on the puck with Bluetooth, only IR.
I think that's the same for most of us in this thread 😞
15 Feb 2024 08:00 PM
same for me - after switch on via IR bluetooth seems to work ok but loses it after a few minutes in standby
15 Feb 2024 08:01 PM
I've followed all instructions. Repeated many times and under no circumstance will the puck wake from standby via Bluetooth, only IR. Once powered up Bluetooth works as expected. It's an IP07 serial puck with remote firmware 5103.4.2
15 Feb 2024 08:02 PM
An IP06 serial number not 07 🤦🏽♂️
16 Feb 2024 12:33 PM
I have followed the instructions really carefully for the last 3 nights. I feel certain now that there is a problem. The puck will only awake from standby with an IR signal, after that BT works as it should. This is a pain as we have a concealed puck in our "show" TV room, which was one of the main reasons for changing to Stream, and I now can't turn it on without getting on my hands and knees and waving the remote up inside the old fireplace. The puck build version is QS024.012.00P, hardware model IP061-ef, remote control firmware 5103.4.2. I hope someone from Sky will now acknowledge there is a problem that still needs to be addressed.
